Originally Posted by
bimbleuk
Hi,
I'm following the tutorials so used the calc_pids.txt attached to those. I'm not confident enough yet to make those sort of changes.
In the summary notes it states both methods can be used with CL/LTFT enabled/disabled so I disabled them for the first runs.
"SELBEN:
SELBEN is a combination of LTFT and WO2BEN, but you can restrict it to only WO2BEN as long as you disable CL/LTFT."
I read the above from the summary notes and assumed it effectively ignored the LTFT in the equations?
Should I have selected "BEN from WB (factor) instead" as the DATA parameter? If I do and re-plot then those are the right figures to paste & multiply?
