Results 1 to 4 of 4
Thread: Please help with changing 4L60e Trans segments to 4L80e
    Apr 2010
    Default Please help with changing 4L60e Trans segments to 4L80e
    Hi, I have just swapped my 4l60e trans to a 4L80e and can't for the life of me find a stock tune that is compatible with my 01290005 COS5 to copy the trans segments. I have attached my tune and would be very greatful if someone could change the segments or email me a tune with the same OS so I could copy the trans cal. Hopefully my tune file is attached. Please email to "philkeys at adam.com.au"
    Cheers, Phil
    What is the base OS of that COS? You wont find a COS with an 80E segment, you will need to go back to your original OS and seg swap that, then apply the COS upgrade and copy your changes over.
    Since it is a COS5, I believe there are only a few OSs that support that, hopefully it will be easy to do.
    EDIT:
    Joe just answered my question right after I posted!
    01290005 is based on 12225074 which is a Holden 2002-2004 OS... these never came with a 4L80E;
    you would need to swap to 12212156 with 4L80E which can then be upgraded to 02020005.
    The other alternative is to run the 4L80E box from your 01290005 trans segment with some harness modifications:
    - invert the 2-3 shift signal by using a relay,
    - drive the TCCPWM signal directly from TCCEN, or indirectly from TCCPWM gated thru a relay controlled by TCCEN (i.e. do not drive TCCPWM directly from TCCPWM),
    - delete the 3-2 control signal.
    Apr 2010
    Thanks for the help it makes sense now. I have found a 02020005 tune with 4L80e so will start cutting and pasting.
  1. 16263425 OS 4L60e to 4L80e swap?
    By LS1FREEK in forum Vortec V6/V8 Specific
    Last Post: February 4th, 2013, 05:02 AM
  2. Using a 4L80E in a 4L60E car..
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 12th, 2009, 05:03 PM
  3. 4L60E to 4L80E swap
    By hquick in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 22nd, 2007, 08:48 PM
  4. Changing from 4L60E to T56
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2006, 05:11 AM
  5. 4l60e ---> 4l80e What changes ?
    By Tydriver in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 2nd, 2006, 02:40 PM
