Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: T42 config critique
  1. #11
    Feb 2013
    Thanks guys,
    Nice to meet you Erik and Joe
    Car is a 2005 Holden but it's a bit of a FrankenCar and I had to use a 2006 OS as Holden never offered this combination of parts.
    The Trans has just about every aftermarket piece in it, I'd actually like it to lock WOT in 3/4 that was my intention when I got the Multplate TC
    Also my file would have been in KMH not sure if that's why the shift points seemed low.
    Engine will run to 7000 but 6500 is more realistic and should make around the 400>450 awkw.
  2. #12
    Feb 2013
    Updated following the suggestions so far
    Have I missed anything?
    (I like to go through it and apply the mods myself so I learn what I'm doing with this software, I forgot to save my Trans file when I converted back from HP COS to stock so lost everything and had to figure out the syntax differences to get this far)
    Very much appreciate the help guys!|
  3. #13
    Feb 2013
    Am I doing something wrong?
    Posted 23 hours ago and it's yet to be "approved"
  4. #14
    Quote Originally Posted by IJ. View Post
    It might be because you posted a link to some other place (the forum thinks it might be spam)...
    ( so I approved it )
    the forum lets you upload/attach you tune files to your posts.
  5. #15
    Feb 2013
    Thanks Joe!
    (figured it must be something I was doing/not doing)
    Missed the attachments button DOH!
    Attachment 14887
  6. #16
    Did you do a compare of your updated file against the old one:
    i.e. open _0002.ctz like usual, and then open _0001.ctz as the alternate file, then click the sideways-double-arrow button, you can click on each of the differences to go to each table...
    and when viewing a table like this, there are current, alternate, difference, percentage, absolute-percentage buttons in the toolbar right above the table.
    I'll take a closer look later.
  7. #17
    Feb 2013
    Yep transferred all of Erik's settings across and did your suggestions as well, just figured I'd get some more experienced input on what I've done just to check!
    I've downloaded all of the Tutorials and will spend some time reading before I ask too many more questions, I spent a day at Swingtan's home getting the basics sorted and also spent a couple of hours re watching Calibrated Success Advanced yesterday (first time I watched it I still had HP so wasn't getting a lot from it)
    Just waiting on a new Billet Pump for the Trans to arrive so I can put the car back together and start sorting the tune!
ID:	14888Click image for larger version.
  8. #18
    What caused the pump to fail...?
  9. #19
    Feb 2013
    Pressure Shock, sort of common I'm led to believe :(
    Was on Cruise at 80 kph, bumped it up to 100 reengaged Cruise and it free revved...
    Did all the Electronic checks I could think of as I'd just set the thing up with an E-85 Sensor so had the panic it was something to do with that (made it 9Km's after putting some E-85 in to test the sensor)
    The Pump had done about 5000Km at that point.
  10. #20
    IJ., hope my tweaks help! If you want it to lockup under WOT that is a pretty quick and easy change, I can make the changes tomorrow (hopefully) so you can get a general idea of what's needed.
    Thanks for the feedback on trans specs, if it's fully built you can run more line pressure, less TM, and faster shift times to really get a firm shift.
  1. Injector Config guidance... I think im getting there....
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: November 6th, 2011, 09:15 AM
  2. DSPS5 config files
    By Gazoink in forum Duramax LB7
    Last Post: May 27th, 2011, 11:45 AM
  3. Please Critique This Tune
    By tatasta in forum Gen III V8 Specific
    Last Post: April 20th, 2009, 02:48 AM
  4. Config Folder in latest update (Build 40)
    By Ninety8C5 in forum FlashScan V2
    Last Post: October 20th, 2008, 03:22 AM
  5. What is the pin config for the RS232 plug?
    By Redline Motorsports in forum FlashScan V2
    Last Post: November 28th, 2006, 04:44 AM
