Results 1 to 5 of 5
Thread: E38 Conversion questions.
    Jul 2011
    Default E38 Conversion questions.
    I am looking at picking up an l76 with 6l80, harness, computers, etc..
    I have a 2002 trans am and i would like some answers.
    First, what is the serial data protocol, is it compatible with the cluster and bcm in the F car. (If i even need that data for the cluster and BCM to work, specific information is hard to find)
    If not is there any very detailed information on it since i can read it into an arduino or something and tell the f car whatever i want.
    I would be a royal pain, but could be worth it and im a fairly decent programmer.
    Next does it have to remain BDW or can i pin in a TPS and IAC and use my cable with my current cruise control/traction control motor.
    ANY information would be helpful. I know i'm in for a lot of work, but i always like building things that look and work as if they were factory.
    Jul 2011
    Upon much more searching i found this, http://forum.efilive.com/showthread....ap-help-needed
    Does the serial data from the E67 just immediately tell the rest of my car what it needs?
    Jul 2011
    Is the protocol for the serial in the e67 the same as the ls1b? Can i swap to an e67 as suggested in this post?
    Im going to bet that the easiest thing to do would be to run the E38/T43 completely standalone in your car. Use the E38 outputs to feed the original LS1 PCM which can drive the cluster/BCM/etc.
    If you want to use an E38/T43, it MUST be DBW. There are no DBC E38s, the only DBC Gen IV is the GMPP crate E67.
    Jul 2011
    I posted a link to this, but mods apparently haven't approved them yet, since im a newb on the board and it doesn't want me posting links.
    can i just use the E67 and T43 out of a CTS-V?
    I have no problem going with DBW, my traction control is always off anyhow.
    Do you know if the ABS depends on any ECM signals?
  1. 3 (E38) engine swaps/conversion's rev limiting at 5,500RPM's
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: September 30th, 2016, 11:13 AM
  2. Replies: 22
    Last Post: January 29th, 2013, 05:57 AM
  3. 0411/E38 Conversion ?
    By 3fingas in forum Gen IV V8 Specific
    Last Post: May 20th, 2012, 01:05 PM
  4. 24x conversion questions
    By monzaaddict in forum Conversions / Aftermarket Parts
    Last Post: July 5th, 2009, 11:11 AM
  5. LSx conversion questions
    By samh_08 in forum Gen III V8 Specific
    Last Post: March 25th, 2009, 05:05 AM
