Results 1 to 8 of 8
Thread: Tips and tricks for a 5.3
    Jan 2011
    Default Tips and tricks for a 5.3
    Hey everybody i just recently picked up an 04 rcsb 1500 truck for the shop. Its already got an intake an exhaust on it installed by the previous owner. I am new to gas efi live but have been around diesel for a while now. I am looking for a couple tips to get this thing running the best it can. Any help is greatly appreciated.
    May 2012
    I would do a MAF Calibration and possibly a VE tune right off.
    I am sure adding some timing may help esp in the pe areas.
    Most LSx engines I hear are way rich also in PE on the upper end. I have heard from sources and seen first hand (2006 GTO) that being true. So reducing the PE % actually helps. But log KR when making those adjustments.
    Im sure its auto, so reducing Tq Management will make you smile during shifts.
    Someting else safe to do is reducing any PE delay that there may be and lowering the TPS % for engagement.
    Just a few starter things.
    Jan 2011
    When u say a maf calibration jst rescale it for the added air flow from the intake. Should i jst log it then make changes from there or how do u mean on the maf
    May 2012
    Yes, your EFILive program came with DOC file to read on how-to do it. Its in the Tutorials Folder in Program Files, EFILive folder on ur computer when u loaded up the EFILive disc to ur PC.
    Theres a few ways to do it I have read and you can search the forum for how-to in the stickys.
    http://forum.efilive.com/showthread....tered-material
    http://forum.efilive.com/showthread....ation-lt-lt-lt
    Jan 2011
    Thanks a bunch it helped alot truck runs ten times better
    May 2012
    No problem. I hope I was of some help Glad u got it going
    Senior Member Quinton's Avatar
    Apr 2013
    Sub'd
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
    Make sure PE enables easier (see 2002 Camaro file, 65%/35% vs 90% for trucks).
  1. Idle Tips & Tricks
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: September 7th, 2018, 08:04 PM
  2. Replies: 37
    Last Post: September 9th, 2016, 07:25 AM
  3. Transmission Tuning Help/Tips/Tricks
    By 68showngo in forum Cummins 5.9L
    Last Post: August 24th, 2014, 12:40 PM
  4. RTACS tricks and tips................
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2007, 01:27 PM
