Results 1 to 6 of 6
Thread: LMM dpf delete P0101 any help? (Canada)
    Mar 2013
    Default LMM dpf delete P0101 any help? (Canada)
    this is my uncle truck did a dpf delete for fuel economy, added turbo brake, keep stock tune and k&n filter! everything was fine but yesterday it threw P0101 mass air flow performance code! do i need to modified the stock mass air flow data for the added flow if there is? any tips?
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Put the stock air filter back in.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Mar 2009
    Quote Originally Posted by dansdieselp View Post
    And get some MAF cleaner to clean the MAF off with as it is probably oiled from the K&N filter.
    Apr 2008
    i have seen where the air will stall when comming to a stop usually with cai, if this is happening while comming to a stop, adjust maf failure air (sorry at work and cant rember the table #)
    stock sucks
    Mar 2013
    new update! it happen again this time he was driving on the highway cruising and the check engine came on again! yeah the first time it was coming to a stop. i did adjust the upper limit thresold
    those are the Maf sensor Parameter any thing to change? the lower value maybe?
    {C0905} P0101 Test Enable, Coolant Temp Low -20,065310 °C
    {C0906} P0101 Test Enable, Coolant Temp High 99,922690 °C
    {C0907} P0101 Test Enable, RPM Low 500,000000 RPM
    {C0908} P0101 Test Enable, RPM High 3100,000000 RPM
    {C0901} P0101 Lower Limit Threshold 20,055499 Grams/Second
    {C0902} P0101 Lower Error Time 15,000000 Seconds
    {C0903} P0101 Upper Limit Threshold 49,999860 Grams/Second
    {C0904} P0101 Upper Error Time 300,000000 Seconds
    Mar 2013
    he did say the truck feel low on power when the light came on!
  1. Dpf/egr delete for an lmm
    By TERYX08 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 18th, 2012, 07:22 AM
  2. LMM DPF/EGR delete with Banks Six gun
    By JustinD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 19th, 2012, 11:50 AM
  3. Dpf delete
    By relentless addiction in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 25th, 2011, 04:41 PM
  4. Dpf delete
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2009, 06:24 AM
  5. 7.5 LMM DPF delete and EFI V2
    By clickjocky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 5th, 2008, 02:36 PM
