Results 1 to 10 of 20
Thread: 2005 gto 6.0 / 4l60e
    May 2012
    Default 2005 gto 6.0 / 4l60e
    Looking for some help here... I'm a transmission guy & had this car droppped on my lap. It has had repeat 3-4 clutch pack failure. After doing some road testing and data logging, I can see that the transmission isn't being commanded to raise line pressure (pcs amperage command never drops below .8, max line pressure is achieved at 0, but realistically, I'd like to see a # in the low .1 range)
    Can someone look at this cars tune and tell me if theres anything obvious?
    TPS works & I'm thinking it's MAF. The reason I say that is that it never exceeded .51g/sec during the road test.
    The other thing that concerns me is that this car has an aftermarket stereo in it and the factory one was a speed sensitive style.
    E40Engine.ctzT42Trans.ctz
    I haven't looked at your files yet, but the MAF is a major concern... unplug the MAF and see if PCS current drops.
    May 2012
    OK shall do.
    As I posted in my other thread, is there a way to map PCS amperage drop to the TPS instead of to the MAF/VE?
    That is not an easy thing to do...
    it can be done mechanically with the vacuum modulator conversion (but vacuum is not linear with throttle position).
    The best way is to fix/replace the MAF and any other problems.
    Do you have another known-good MAF to try...?
    May 2012
    I do not have a known good one.
    That was my concern with the vacuum proposition, since the cam is relatively large, it will always have low vacuum and likely shift very hard, ie - not very streetable.
    May 2012
    If I unplug the MAF, then PCS amperage should drop to max?
    Vacuum/MAP shouldnt be messing with shifts, the 4speeds are done with as pattern vs TQ. If the MAF isnt operating correctly, it will max out line pressures and shifts will be brutal.
    Id try applying the MAF Patch B9901 and seeing if that makes a difference, then Id try going SD (have to apply B9902). Swap MAFs if you can.
    Side note, it would be good to have the Torque Model added to E40s, Ill put a request in for it.
    May 2012
    I *could* and *would* go SD, but then I'm waaaaaaaaaaay out of my realm as a novice tuner. Dmax, I can handle, LS I have no experience or knowledge. No clue how to tune these things, my responsibility here is to get this transmission to have pressure rise.
    Quite frankly, whoever tuned this car is probably as clueless as I am. The idle quality sucks for a .222' @ .050" cam. It makes power, but it's clearly not reliable.
    Quote Originally Posted by 02CCSB View Post
    If the transmission fault max pressure table has the MAF DTC's enabled, then commanded pressure goes to max (PCS current drops to almost zero); otherwise if the MAF DTC's are disabled in this table, the VE table is used to calculate torque and commanded pressure (you will see PCS current drop as load increases).
  1. 2005 GTO E40 ECU help please
    By billion01 in forum Gen IV V8 Specific
    Last Post: September 18th, 2012, 02:34 PM
  2. help with a 2005 gto powertrain in a 56 bentley
    By TonyArme in forum Gen IV V8 Specific
    Last Post: June 17th, 2012, 02:54 PM
  3. looking for a 2005 ls2 hsv gto stock tune
    By gmperformancecentre in forum Gen IV V8 Specific
    Last Post: July 18th, 2008, 07:52 PM
  4. Replies: 0
    Last Post: February 6th, 2006, 10:34 AM
  5. 2005 GTO
    By Anonymous in forum Purchase and Shipping
    Last Post: February 6th, 2006, 08:31 AM
