Results 1 to 3 of 3
Thread: 6.0 LS2 / T42 GTO - make trans line pressure TPS dependant?
    May 2012
    Default 6.0 LS2 / T42 GTO - make trans line pressure TPS dependant?
    Anyone know how this is done? ie - make the EPC solenoid react to TPS/APPS position rather than MAF/VE?
    Can't be done directly in the tune...
    and I'm not sure how it would be done outside the tune...
    ( the PCS solenoid sinks current, this current would have to be inversely proportional to TPS voltage, you would need a voltage-to-current amplifier/op-amp circuit that maps 0.0V-5.0V TPS voltage to 1.1A-0.0A PCS current (inverse relationship) with the ability to supply upto 1.1A...
    I don't know of anyone doing this for the TPS->PCS control ).
    May 2012
    OK, so basically, my options are either dial in that MAF properly (if it is found to not be defective) and/or install a mechanical vacuum modulator in the trans and disable the PCS codes... both are do-able...
  1. line pressure in efilive
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 12th, 2012, 06:20 AM
  2. 4L80E line pressure
    By pullincrazy88 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 17th, 2010, 12:56 PM
  3. line pressure
    By dezzi in forum Allison 5 & 6 Speed
    Last Post: January 18th, 2010, 01:59 AM
  4. Problems with Line Pressure
    By goldbergv95 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 5th, 2009, 04:41 AM
  5. Line Pressure Oddity
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 8th, 2008, 04:22 AM
