Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 82
Thread: Looking for some pointers on maf tuning.
  1. #21
    Member TJWells's Avatar
    Apr 2008
    Heres what I see when I right click.
    Can you tell me which folder I should look in to find calc_pids.text file for you to look at. I swear I have copied that file a dozen times, but I can't find it now!
    I tried a small log to see if I have the map and pids set up right and I failed.
  2. #22
    Apr 2008
    Found It!
    calc_pids.txt
  3. #23
    Apr 2008
    E38_0019.efi
    Ok why wont the D and E maps work?
  4. #24
    Apr 2008
    Morning!
    Ok latest log I've done trying to log B1097,B1098. When I open my maps I have lines through all parameters. If I goto the pids tab I can highlight calc.W02ben and then I have no line through it in my map. However MAF (g/sec.) and MAFFREQ (Hz) I can't get to report. I am using BBX to record data and the only pids I can find are MAF and MAFFREQ2. What am I doing wrong.?
  5. #25
    Mar 2011
    Default Re: Looking for some pointers on maf tuning.
    I believe you need to log MAFREQ2 on the E38. It's the one I use for my Camaro.
  6. #26
    Apr 2008
    Quote Originally Posted by Jayrcr3 View Post
    That's what I thought too. so I logged that originally and I still have a line through it on my map.
  7. #27
    Mar 2011
ID:	14973Click image for larger version.
ID:	14974I'm not an expert at this, but I will tell you what I see by looking at your log posted above.
    In your PID's tab you don't have "BEN Factor Bank 1, Serial Wideband, E38 style"
    selected. This is the PID that should be selected in your MAP "Parameter" under the data tab of the map.
    Looking at your log, once I selected that PID and changed the parameter to BEN Factor Bank 1..... the map comes up for me.
  8. #28
    Apr 2008
    Thanks for the help Jay.
    Can I use this to correct B1097 and B1098?
    Those tables use MAFFREQ In Hz. and MAF g/sec. Your table uses MAFFREQ and RPM. I was trying to setup per Joecar's post 13 this thread If this works I'll use it and be done.
  9. #29
    Mar 2011
    You can change the column value to MAF g/sec. It will still work.
    I just loaded my tune, and can't find B1097 and B1098 tables for my 2011 Camaro. The only Maf Table I can find is B1099. It's the MAF Frequency Conversion table. This is the one that I have adjusted to dial in the MAF.
    After you get a log done you will copy the values from the MAF map in the scan tool and paste and multiply them into your tune. This will slightly adjust your MAF table to dial it in.
Name:	Maf Freq Conv.JPG
  10. #30
    Quote Originally Posted by TJWells View Post
    E38_0019.efi
    Post screenshots of their properties.
  1. Tuning changes going from 85mm MAF to LS7 or other 100mm MAF?
    By PRAY in forum E37, E38 & E67 PFI ECM's
    Last Post: November 21st, 2012, 02:11 AM
  2. timing pointers. . .
    By truethinker in forum Gen III V8 Specific
    Last Post: June 25th, 2012, 04:23 AM
  3. 2005 silverado 5.3 need some tuning pointers
    By whiteboy631 in forum Gen III V8 Specific
    Last Post: December 22nd, 2010, 10:00 AM
  4. New to EFI need some pointers plz
    By shadyst in forum Gen III V8 Specific
    Last Post: November 24th, 2009, 04:58 PM
  5. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 03:58 PM
