Results 1 to 5 of 5
Thread: Weird spark issue.
    Oct 2011
    Default Weird spark issue.
    Hey guys,
    So I'm at the track doing some testing with our 2010 camaro. It's procharged with a 4L80 conversion, zr1 map sensor. I'm having a hard time. It's pulling timing from 5200rpm and up. Is it because the ecu doesn't recognize a trans (since its standalone, thinks its in neutral) or is it some weird torque setting/ map setting? Or something else that I'm missing. I've been going through the tune trying to narrow it down but I feel like I'm missing something stupid. Can anyone shoot me in the right direction? I can't post a log because I'm on my cellphone right now.
    Dec 2007
    How much is it pulling 1 degree or 10?
    David McLain
    www.etdrag.com
    Oct 2011
    It varies but it's bringing my final timing way down (5-10 deg). It's driving me crazy
    Dec 2007
    Try reducing b5156 Max spark retard, as long as its not knock causing the retard, that is what i would try next. If you have torque reduction shut off b0515 that is.
    David McLain
    www.etdrag.com
    Oct 2011
    Quote Originally Posted by etmotorsports View Post
    Thanks man, I though about doing that wasn't sure if it was going to help. Thanks man I'm going to give it a go
  1. 05 lly weird issue after 4 days
    By House in forum Duramax LLY
    Last Post: August 30th, 2012, 07:49 AM
  2. Weird spark drop
    By samh_08 in forum Gen III V8 Specific
    Last Post: June 4th, 2009, 11:58 PM
  3. Very weird Serial Issue
    By Highlander in forum General
    Last Post: May 17th, 2009, 09:30 PM
  4. weird spark drop
    By jfclubby in forum Gen III V8 Specific
    Last Post: September 2nd, 2008, 03:13 AM
  5. Swapped MAFS, now weird issue
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2008, 05:25 AM
