Results 1 to 2 of 2
Thread: Can you not log ECM and TMC at the same time?
    Mar 2008
    Default Can you not log ECM and TMC at the same time?
    I use to log a few TCM pids while logging the ECM via the V2 before updates. Now it won't let me select them both in the Scan and Tune under just the ECM. I don't see a way to log both ECM and TCM at the same time. If I can find one of my old Options.txt can I use it? I'm using build 211
    06 GMC 2500 CCSB SLT LBZ 4X4
    These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
    You should be using build 224, available here:
    https://www.efilive.com/index.php?op...=48&Itemid=133
    When you add a new Scan Tool controller, just select an ECM and a TCM like the image below.
  1. Is it possible to log the trany shifts and engine at the same time??
    By Dragbear in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 9th, 2013, 04:27 AM
  2. Dual fueler SURGE AT WOT issue ECM overcorrecting? PID LOOP?..Log Inside
    By Dmaxink in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 26th, 2012, 09:18 AM
  3. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  4. Can BBL log E38 and T43 at same time?
    By zbadestz in forum FlashScan V2 BB Logging
    Last Post: May 6th, 2012, 01:13 PM
  5. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
