I am having some issues with my truck as far as having to go the the dealer to get the TIPM and ABS module flashed. The other day I was trying to track down an injector rattle/ticking, so i wanted to flash in an old stock tune to see if that effected it at all. Well the first one I flashed in was the wrong one (my mistake) it was a stock federal file that Zach at Starlite sent me awhile back which did not have the vin changed yet... so it started up and died right after. I had realized what happend and then when and found the actual original tune that came out of my truck and flashed that in and it started fine but had the ABS, Brake, and air bag lights on (Im thinking that my original stock file that I flashed in caused the issues because I had ran multiple different programmers before EFI Live, including a bullydog....). Zach told me I would need to go to the dealer to get a reflash so thats what i did. They reflashed the ECM and the TIPM but it would not let them reflash the ABS module for some reason (reflashing the TIPM did get rid of the codes showing up for that). We tried disconnecting the ABS module and the reconnecting it with no luck. I also tried driving the truck for 2 separate trips of over 8 miles each but that did not help either. All the lights are still on in the dash and its showing ABS C2206 Configuration Mismatch. Im not sure where to go from here... If anyone can give some advise I would appreciate it. Thanks
