will a dealer reflash change an OS and or calibration? or do they just reflash you with the same file you already have in the truck?
what CAN happen if you use a different OS and or calibration in your truck?
can you change a calibration or OS simply by changing it with efi live the same way you can change the VIN? will that screw anything up? will it even change anything or is it just the title you are changing?
