Did you take care of this:
Your B3505 is dangerously lean in the lower right quadrant (engine damage imminent if you operate at WOT or significantly high load)...
do this immediately:
- in tunetool, go Edit->Properties, set fueling units to EQR, restart tunetool;
- set your B3605 to stock (high MAP columns should be at EQR 1.165 at operating temperature);
- set B3618 to 1.165 EQR all across;
- set B3616 to 65% below 3000 rpm, and to 35% above 3000 rpm.
