I will fool with it some more tommorow and see what it says when I check status
I'm having this same issue READING a LLY, pulled radio, radio amp, and info fuses. Tried door open and closed.
First he was getting the $0101 no data received, pulled the radio amp fuse and closed the door and it began to read.
Once reading it gave error $11 mode not supported.
Upon trying to read again we cant get past the $0101 no data received again.
Any suggestions?
Are you running the latest release ? Updated firmware ?
He just downloaded it today, and I had him check the firmware and bootblock, they are both the same as the files in the browse folder in EFI Explorer. This is an Autocal.
Did he update his BBX scripts ?
I read in another thread that an end user had to delete all EFI Live related files and re-download and install from the website again. I informed him of this and he says that he will try tomorrow morning. Id really like to get his ECM read. Ive never had a problem like this before, but it was bound to happen.
Mine wasn't a problem reading mine was after flashing and trying to flash again I was getting the error.
Power cycle the key on and off a few times after the $0101 error, that should restore the controller.
Yeah we tried alt keys, low speed, etc and cant get it to even start reading. It started to read and move the green bar one time, and stopped after a few seconds giving the $11 "mode not supported" error code.
