How many times Tony? And how long should he wait between on's and off's?
Can you not read LLY controllers with V8? I had him try both V7 and V8 and he gets the same error in both software versions.
I worked with Paul on this several weeks ago when RC2 or RC3 was out and we got any issues with $0101 fixed with the LLY Controller, I know I am not having any issues at all and I do a lot of bench and in truck flashes.
LLY controllers are the worst of them all, I sometimes have to check security on an LLY 2 or 3 times prior to a flash or I even get the bootloader rejected error message in V7.5.
Set you V2 up for saving trace files and then email them to Paul so he can see what it's doing, but we worked on it over several days back in early April and it was all fixed and we tried are best to make it screw up again and could not.
Good Luck
If we cant get it to work I'll just buy the Autocal back from him and have him send his ECM to you Tony. I don't have a bench harness.
