Results 1 to 5 of 5
Thread: Another "Bootloader Rejected" thread
    Oct 2005
    Default Another "Bootloader Rejected" thread
    I did a couple of flashes and then put the truck on the battery charger while I went inside to make some more changes to the tune. Took the charger off, went to flash again and this is what I get:
    What changed?
    EFILive software and firmware have been updated to no avail.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Oct 2005
    Seems to me that during the last flash the full flash option may have been greyed out in EFILive. Looks OK today but still cannot access the PCM.
    Oct 2005
    V7.5.7 Build 230, V8.2.2.224
    Have you tried flashing it with V8? If not please do and if it still fails then locate the V8 trace file in the folder: \My Documents\EFILive\V8\Trace
    The file will be called something like: LS1B_W_YYYYMMDD_HHMMSS.htx
    where
    YYYYMMDD is the year, month and day
    HHMMSS is the hour,minute, second
    that you attempted to perform the reflash.
    Send the *.htx file to me at paul@efilive.com - include a link to this thread so I know what its about.
    Oct 2005
    Yes I did try flashing with V8 also. The PCM cannot be read either. email sent
    I am wondering if this could be caused by a messed up throttle area scaler value. I didn't notice that I had shifted the decimal place. My Roadrunner didn't like that tune file either, but survived it. I have it running on the RR for now, but last time I used the RR strange things were happening.
  1. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. Where did my "robbed again" thread go?
    By mistermike in forum Lounge
    Last Post: July 23rd, 2007, 03:19 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
