Results 1 to 6 of 6
Thread: E67 ECM Lambda
    Dec 2010
    Default E67 ECM Lambda
    Does anyone no if the GM E67 ECM and run package will run 4 x lambda,i have it hooked up to a stock LS7 with 2 x lambda and need to try and get through a Euro 4 test with 4.
    What are you talking about?
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Dec 2010
    Default E67
    Quote Originally Posted by Redline Motorsports View Post
    Euro 4 is a strict emmission test and is explained on wicki,I was hoping so to find out if the E67 ECM is capable of running all the systems for the test
    Are you talking about pre-cat and post cat O2 sensors on each bank...?
    I googled it and wiki has an article: http://en.wikipedia.org/wiki/Europea...sion_standards
    so according to the table in the wiki, Euro 4 is a standard for the level of emissions...
    if you tune the ECM correctly and rub closed loop you can achieve CO/NO/HC levels much lower than shown in that table for Euro 4...
    i.e. from what I see/understand, the level of emissions is purely a function of the tune and how well it runs in CL.
    Dec 2010
    Joecar correct 02 sensors before and after the cat on each bank,so the test includes checking all 4 working correctly,even is the emmisions are reading low the circuits have to test correctly ultimately can the E67 run do any of this
  1. Unique 09 e67 os ecm
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: September 12th, 2011, 12:23 AM
  2. Not connection to E67 ECM
    By khalidmmukhtar in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 07:40 AM
  3. what tune can i use for a 6.2L VVT W/E67 ECM
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: January 16th, 2009, 12:03 PM
  4. New part number for E67 ecm?
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: June 7th, 2007, 12:21 PM
  5. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 06:02 PM
