Results 1 to 10 of 11
Thread: $0333 error
    May 2013
    Default $0333 error
    Just got my autocal in and every time I try to load it on to my truck I get this code. Any ideas?
    Nov 2010
    Default $0333 error
    Needs to be updated with current firmware.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    May 2013
    Thanks i'll try that.
    May 2013
    Smh I updated to the newest everything and still pops the $0333 code.
    Nov 2005
    From the error code list $0033 is
    Security Access Denied ($33)
    The controller has either not been successfully unlocked or has re-armed itself prior to FlashScan or AutoCal making a secure request.
    When using V8 pass-thru reading and/or flashing, try selecting “Assume Lock may be Faulty” and “Try Alt Keys” and retry the operation.
    Have you spoken to your tuner about your issue? The tuner who provided you with your AutoCal device is your first point of call for product support.
    Cheers
    Cindy
    May 2013
    Yes I have spoken with him. He said he's working on the issue I was just trying to see if anyone else had ran into this problem.
    May 2009
    I had same issue on lb7 I had previously tuned. This happened with v2 in pass thru with v7.5. Tried v8 which gave error that controller locked with custom key. Checked status with v7.5 it was unlocked so ran v7.5 as administrator and it went thru. Also on my windows 8 laptop I get an error when opening speedo calculator but it opens and seems to work correctly. My windows 7 laptop does not do this. Both are running on current software/firmware.
    May 2009
    This the error message I get with windows 8
    May 2013
    So I went in and changed those settings went to the truck and after 3 tries it read the stock tune so then I scroll down to pit on my tunes and they are gone. This has to be the most frustrating tuner I've ever heard of.
    May 2013
    And i'm back to getting the $0333 code
  1. Replies: 8
    Last Post: March 20th, 2018, 06:47 AM
  2. $0333 Error
    By Dmaxink in forum AutoCal
    Last Post: August 8th, 2012, 01:24 PM
  3. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 03:22 PM
  4. Error
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 09:27 AM
