Results 1 to 10 of 10
Thread: Please help : Autocal display goes wonky when attached to OBD (LMM)
    May 2013
    Default Please help : Autocal display goes wonky when attached to OBD (LMM)
    2007.5LMM
    Received Autocal and first updated firmware (2.07.39) and bootblock (2.07.04) on computer. When attached to computer the display is fine but shows DTC $0280
    When I attempted to attach to truck and read stock tune the screen turned blue but no display. Attempted multiple times and finally got a display but the letters are all screwed up and you can't read it. According to other forums I went into BBX and re-programmed scan/tune with only selecting LMM E35B. No change.
    I did manage to read the stock tune and can see it in Explorer. But I am afraid of flashing the tunes to the truck with the display like this as it's hard to read whats happening.
    Any suggestions I need to get this thing going. My tuner suggested I use this forum.
    Sorry should also add I have pulled suggested fuses as well and OBD is powered/functional as Edge Insight works fine.
    Thank you
    The AutoCal screen corruption is a temperature related problem that has been fixed in the next firmware update which is due out next week. Keeping AutoCal warm can help prevent the screen from corrupting or staying blank. Cold temperatures cause the clock timings in the LCD control circuitry to drift by a very tiny amount (less than a millionth of a second) which prevents screen updates from the CPU being applied correctly.
    It is listed as a "current issue" here: http://forum.efilive.com/showthread....se-Apr-23-2013
    Note: FlashScan and AutoCal are not rated for use at temperatures below 0 degC or -32 DegF.
    Nov 2007
    I think you mean 0 degC or +32degF
    Quote Originally Posted by kangsta View Post
    Yes, I do...
    Now go easy on Paul, I'm 40 and they never done learnt me Fahrenheit at school.
    Nov 2007
    haha as far as the NSW education system goes I think Fahrenheit got mentioned more in History lessons than Science
    The only redeeming thing about US published engineering books is you start to get a feel for imperial units...
    It got learnt in 4rd grade (NSW) in 1971
    as did these little gems:
    Code:
       12 inches   = 1 foot
        3 feet     = 1 yard
      5.5 yards    = 1 rod = 1 pole = 1 perch
        4 rods     = 1 chain
       10 chains   = 1 furlong
        8 furlongs = 1 mile
        3 miles    = 1 league
        6 feet     = 1 fathom
       25 links    = 1 rod
        1 perch    = 1 rod x 1 rod
        1 rood     = 1 furlong x 1 rod
        1 acre     = 1 furlong x 1 chain
       40 perches  = 1 rood
        4 roods    = 1 acre
      640 acres    = 1 section = 1 sq mile
       36 sections = 1 township
    In the middle of 5th grade they took away our Imperial Maths books and replaced them with otherwise identical Metric editions.
    Nov 2007
    A similar thing happened when i did my Mech Eng degree at UNSW. We used an imperial design book, the next year it was the same book but a metric version. Mind you this was at a time when metric was already mainstream!
    Now Joe, those imperial conversions make perfect sense, much better than the confusing communist spawned metric system where....
    10mm = 1cm
    100mm = 10cm
    1000mm = 100cm
    1cm = 0.01 meters
    10cm = 0.1 meters
    100cm = 1 meter
    1 meter = 0.001 kilometers
    10 meters = 0.01 kilometers
    100 meters = 0.1 kilometers
    1000 meters = 1 kilometer
    0 degC = Water Freezes
    100 degC = Water Boils
    I better stop, someone will get upset
    May 2013
    Thank you so much for the info. Now I am in Canada but it's not that cold. Today was about 18 degrees C and the screen was all screwy. So is it safe to assume I can flash the tunes and everything will be ok? The bummer is if this is supposed to be a scan tool/code reader it's hard to know a code when you can't read it... especially since its below 0degC about a 1/3 of the year up here.
  1. brand new,Autocal Stuck on "display DTC's" screen?
    By undergroundak in forum AutoCal
    Last Post: February 6th, 2013, 06:32 PM
  2. wondering about my 02's log attached
    By Gregs in forum Petrol / Gas
    Last Post: October 12th, 2010, 01:03 PM
  3. Where is all my timing going??? Log attached
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2010, 05:55 AM
  4. Reading OBD-I w/ OBD-II plug car?
    By Garry in forum General
    Last Post: February 27th, 2007, 09:07 AM
  5. scantool display to use as dash display?
    By ace68 in forum Lounge
    Last Post: March 3rd, 2006, 06:50 AM
