Results 1 to 3 of 3
Thread: Trouble upgrading to a COS.
    Default Trouble upgrading to a COS.
    Hello,
    I am trying to set up a 12212156 OS for the 02020003 COS so I can run a 3 bar MAP on a turbo setup. Each time I try to upgrade I have also tried a few other PCM's with different OS, it starts the process and gets to around 98% complete then says the operation failed. Is there a different COS I need to use or is this an issue since the 4/23 Update?
    Quote Originally Posted by Schwanke Engines View Post
    Hello,
    Can you locate the *.blx trace file that would have been created during each of the failed flash attempts. The file(s) will be located in
    \My Documents\EFILive\V7.5\Bug Reports and they will be named something like: 20130430_165100_download.blx
    where the first set of digits is the date (YYYYMMDD) and the second set is the time (HHMMSS) that the flash was attempted.
    Send them to paul@efilive.com with a link to this thread.
    When I check that file path, there is only one Download File. And I tried it several times
  1. Is there any COS for e38 other than the ethanol COS ?
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: July 8th, 2012, 09:54 PM
  2. switched from COS 3 to COS 5 now reduced power mode
    By CRU SS N in forum Custom Operating Systems
    Last Post: April 26th, 2010, 04:48 PM
  3. COS 3 or COS 5 for 2000 Corvette?
    By onfire in forum Custom Operating Systems
    Last Post: July 29th, 2009, 04:22 AM
  4. COS 3 or COS 5 for a 2000 corvette?
    By onfire in forum Gen III V8 Specific
    Last Post: July 7th, 2009, 06:59 AM
  5. Need help upgrading from V1 to V2 (error when upgrading)
    By tunedportcj5 in forum FlashScan V2
    Last Post: November 8th, 2008, 04:35 AM
