Results 1 to 9 of 9
Thread: full BBL support for newer controllers?
    Dec 2006
    Default full BBL support for newer controllers?
    In what state of support is BBL for the newest controllers? Seems I can only BBL T76 PIDS on my '13 Buick Verano T. I have not been able to select and log E39A PIDS.
    Is it because I'm doing it wrong again?
    8.7 @ 84 (1/8 mile) bolt-ons
    Just select it as E39 and you should be fine, I can see everything has been defined.
    Dec 2006
    Hmm, I realize that I am way behind in my understanding of BBX. This has become #1 priority as these days I am trying to do things right if possible.
    I was unable to select any E39 or E39A PIDS, this was while connected to the vehicle with the laptop and in S&T. In addition, it "glitched" - as in it gave me the option to select T76 PIDS into the V2 sometimes, but more often it remained blank. I tried clicking on every single thing on the screen.
    Am I even in the right application? What I am trying to accomplish is a nice BBL with mostly engine PIDS to see what my tunes are doing.
    Please help me get up to speed as the days of pass through and V7 are all but gone!
    These links show how-to pics (from an older version of V8 S&T):
    You basically have to do this:
    - install the latest V7/V8 build versions;
    - flash the latest firmware into V2;
    - edit BBx config (Scan: edit/add pidlists for your controllers; Tune: add entries for your controllers);
    - save BBx config and do Program All to V2.
    Dec 2006
    Thanks Joe! The first two arevalready done and I "think" I am doing the other two steps. I will let you know how it turns out!
    Dec 2006
    These are my first BBL files, all just cruising. Some good data but I was unable to select and E39 PIDs that I wanted directly. Will try again.
    Dec 2006
    Just to be clear, can I program / set up the entire BBL for the vehicle without being connected to it? Or must the V2 be hooked up to the car to see which PIDs are valid?
    Quote Originally Posted by Boost View Post
    Yes, you can set up entire BBx without being connected (you select the ECM/TCM controllers).
    If some pids are not valid, then when you goto BBL log, V2 tells you some pids are invalid (and it asks you if you want to continue).
    Dec 2006
    Thank you!
  1. Cummins BBL Support
    By KhakiCummins in forum FlashScan V2 BB Logging
    Last Post: April 21st, 2013, 01:36 PM
  2. Replies: 5
    Last Post: July 20th, 2011, 04:00 PM
  3. T42 Controllers All the Same?
    By ScarabEpic22 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 11th, 2009, 09:27 PM
  4. 4.2L I6 LL8 full OS support when??
    By ScarabEpic22 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2006, 12:30 PM
