How can I find my build versions? I am on boot block 2.07.04 and firmware 2.07.39
In V7 scantool/tunetool: Help->About
In V8 S&T: see upper right.
Joe I have the same problem with E39 2013 Camaro V6
when i tried to read i noticed an error : Request Out of Range ($31)
Also there is no TCM detected while the car is A6
my build is V7.5 Build 211 V8 Build 203
EFILive Tuner
Was it working with previous versions? That response sounds like maybe a locked TCM too.
That sounds like the ECM is rebooting before the read begins, it might be an E39A, try updating everything and use the Autodetect function in V8, it'll choose the right E39 type for you.
I used the Auto detect it says it is E39
I was afraid to update to the latest version as I'm working on a lot of cars daily but i will update to the latest version today
I hoop every thing goes without problems
EFILive Tuner
Remember: after you flash the newest firmware into V2, goto V8 S&T BBx and do Format Config Filesys, then do Program All of your pidlists/controllers.
Why should i format the config file and program it again ?
I tried to read scan and write and every thing seems OK !!
EFILive Tuner
