09 E38 Corvette with a manual transmission. Car is modified and tune is speed density. When cold at low speeds the car will accelerate on its own, I push in the clutch but before I can kill the engine it hits the rev limiter. Only seems to happen with AC on when cold. When cruising on the freeway hot or cold with AC on, throttle will stick at certain RPM. What are the possible tables I should look at?
