Results 1 to 4 of 4
Thread: Timing Calculator
    Junior Member xploitdiesel's Avatar
    Jun 2012
    Default Timing Calculator
    I know everyone uses Josh's timing calculator in excel...but since it's been done on the cummins and works well at that, I think if it'd be possible to go back and add that it'd be awesome. I'm sure its been mentioned and you have a bunch to do on the new innovations...just wondering
    I will just say that we do not use these calculators, as they skip over one the most important variables, load.
    Custom Tuning Services
    Jun 2012
    With all due respect, I do use the calculators. This also proves true for every tuner I know. Does this mean the tune won't need tweaking? No..it usually does, but the calculator definitely gets you in the ball park. If you do research you'll find calculators for the cummins that do show you how to correlate calculated load into the mix. We could take a poll on it and I bet you'll find that more people use the calculators than those that don't.
    Nov 2009
    I use the calculator as a base value...
    -Kory
    http://www.PPEI.com/
  1. Timing Calculator
    By mstordahl in forum Cummins 5.9L
    Last Post: November 1st, 2012, 10:27 AM
  2. Timing Table Calculator
    By Wheelz in forum General (Diesel)
    Last Post: August 27th, 2012, 12:24 PM
  3. Timing Calculator for 6.7
    By Compcowboy in forum Cummins 6.7L
    Last Post: March 27th, 2012, 08:12 PM
