I am having trouble with my v-2 logging. It logs fine until the engine gets to around 2500-3000 RPM, and then it freezes up until you go below that rpm again. The green and yellow lights go out when it does it. The engine is on a engine dyno with a harness I made up I have the com wires twisted and wrapped in foil they are comunication wired from a communication cable. I have looked all through my laptop for settings to disable active protection if it has it I cant find it. It really seems to be a frequency or vibration causing the loss in communication.
Any Ideas would be great. I dont think I can log without the laptop Being a Cumins ECM??
