Results 1 to 10 of 13
Thread: 2004.5 LLY Stock Tune File Needed
    Apr 2012
    Default 2004.5 LLY Stock Tune File Needed
    I am in need of a stock tune file for an LLY with the OS and segments listed below. I have found some that have the same OS but the system segments does not match. The truck I am tuning has a Superchips on it and the tuner was stolen. I will be putting a dsp-2 in and I don't trust making any changes and flashing it back in the truck.
    OS 15141668
    Cal 15141667
    Engine Operation 15245557
    Engine Diagnostics 15787618
    Engine 15245549
    Fuel System 15136389
    System 15282641
    Speedometer 15087291
    2015 Chevy 2500 DC 4x4 LML Stock w/EPA friendly tuning.
    2008 GMC 2500 CC 4x4 LMM DSP-5, Transgo Jr,Converter Flow Valve, Sun Coast Triple Disc,4'' Exhaust,Lift pump,Edge Evo for the gauges.
    2006 Chevy 2500 CC 4x4 LBZ Built Engine, Built Trans, Goerend R, S475/Stock, 30% over injectors.
    South of the Rio Grande
    Mar 2009
    If you can find several tune files with the same OS but with the segments you need, you can do segment swaps to build the OEM tune file. I've done this for the DURABURBS I have tuned for people to get the correct fuel system and other options to work properly.
    Apr 2012
    Quote Originally Posted by THEFERMANATOR View Post
    I have a stock file with the same OS but it is the system segment that has caused issues in the past with the LB7's. I have never tried to do a segment swap. How are you doing that?
    Senior Member Quinton's Avatar
    Apr 2013
    Where you from bigtexas? Ill check and see what I got when I get to the house this evening.
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
    Apr 2012
    Quote Originally Posted by Quinton View Post
    Cleveland Area
    May 2009
    Quote Originally Posted by thefermanator View Post
    if you can find several tune files with the same os but with the segments you need, you can do segment swaps to build the oem tune file. I've done this for the duraburbs i have tuned for people to get the correct fuel system and other options to work properly.
    please do elaborate on how this is accomplished, as it would be very handy for the above mentioned situations!
    Dec 2005
    Don't do it........only fuel segments seem to work, lemme see if I have a stock file for you to match what you need.
    www.mscservices.net
    Mar 2012
    Default os & cal
    here you go
    Mar 2009
    Quote Originally Posted by GMC-2002-Dmax View Post
    I know they work on LBZ's, but never tried an LLY.
  1. stock file needed 05 corvette t42 2.72 gear
    By Dale C in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 2nd, 2013, 11:01 AM
  2. ANOTHER LLY Problem, (cant pull stock file)
    By TRUBBS in forum Duramax LLY
    Last Post: June 3rd, 2012, 02:53 PM
  3. 2004 Monaro/GTO Pontiac 5.7 mafless tune needed.
    By gold-nuggets in forum FlashScan V2
    Last Post: June 10th, 2011, 01:34 AM
  4. 2007 Impala SS 5.3 Stock File Needed
    By finishline in forum Gen IV V8 Specific
    Last Post: March 24th, 2009, 11:50 AM
  5. Stock LLY file?
    By Wasted Income in forum Duramax LLY
    Last Post: December 25th, 2005, 04:27 PM
