Results 1 to 10 of 20
Thread: 06 gmc envoy p12 pcm issue
    Aug 2007
    Default 06 gmc envoy p12 pcm issue
    i need help, read and saved the original tune. made a few changes, resaved it then linked back up the licence the pcm. next went to load file and now its telling me ''error, bootloader reject'', missing calibration file.
    at this point i cant re-read the pcm, load a file or anything. even if i check staus it says missing cali file. ive tried doing it on alt keys and low speed.
    what next?
    thx
    Quote Originally Posted by cyclerage View Post
    what next?
    thx
    Installed the latest software from here: https://www.efilive.com/index.php?op...=48&Itemid=133
    And try reading/flashing using the V8 software.
    Aug 2007
    I spoke with chuck cow earlier and he recommended the same. Hope it works. Thanks!
    Aug 2007
    no luck, looks like pcm is dead. wont connect at all. V2 cant even show pcm details
    Oct 2006
    Disconnect the battery negative terminal (last resort), if the vehicle will start start it and then try again, don't know why the P12 acts up sometimes.
    Make sure and have the P12 PCM selected as the type of PCM (sometimes the V2 reverts to no PCM type).
    Have never had any trouble flashing any P12 other than you have to do a dance sometimes with key on and off.
    2006 Trailblazer
    Aug 2007
    i tried pulling the bat a few times, no change. the other day I was getting ( no clac file), today im getting no pcm found, no ses light (light for a few seconds but shuts off), stil wont crank, run, etc
    ive tried reading it with v7.5, calc flach & full flash. On v8 I tried reading & clac flash, wont evn give me the option to full flash on v8
    Aug 2007
    ive checked all the fuses. I do have power at the aldl. I can pull all the codes from the other modules using just the V2, everything is non-comuncation codes from me clearing them the other day.
    am i correct in assuming the pcm needs to be reflashed with a tech2?
    Oct 2006
    Not necessarily, if you can get the V2 to communicate you can do a full flash of the old .tun and be fine.
    I had this happen one time, scared me, I did a key off, unhooked from the PCM and reconnected, got com and full flashed, everything was fine after that.
    Did you try a flash and it fail while flashing? I have recovered from that too, same thing disconnected from PCM key off, reconnected and got com, and full flashed, everything was fine.
    Odd it just wigged out after licensing of the PCM.
    2006 Trailblazer
    Aug 2007
    so, key off but leave the battery still hooked up and unplug the connextors from the pcm?
    Oct 2006
    Did you you do bootblock update when you updated, that can cause a cal error.
    No, do not take connections loose from PCM without taking negative terminal off first.
    I mean key off, disconnect the cable of the V2 then reattach the the V2 and key back on to the second position just before start.
    Then try and see if the Full Flash option is present.
    I have recovered from this before on a P12.
    2006 Trailblazer
  1. P12 PCM file
    By Chevy366 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 29th, 2009, 09:28 AM
  2. Part # for P12 PCM?
    By ScarabEpic22 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 30th, 2008, 05:32 PM
  3. Looking for PCM P/N for L21 454 (99 P12 RV Chassis)
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: August 20th, 2007, 04:54 PM
  4. Reading the P12 PCM
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2007, 10:48 PM
