Results 1 to 4 of 4
Thread: Properly scaling Map offsets and scalars.
    Aug 2012
    Default Properly scaling Map offsets and scalars.
    Hello,
    I was looking for information on how to properly scale your map sensor and find the correct offsets. I thought there was a sticky somewhere online of the common Delphi and ACdelco 2 and 3 bar sensors but all i found was pat numbers. It seems everyone is just guessing at what the scalars should be but there isnt any information on how to correctly find the information.
    can someone show me an example on how to properly find the equations and apply test it in the software. This could be a very good sticky when finished. Thank you.
    Aug 2012
    Anyone!
    Set values for scaler/offset and then with a vacuum pump/gauge see what the MAP pid reads out... compare with vac gauge (converted to absolute pressure).
    Aug 2012
    Thank you Joe seems simple enough.
  1. Scaling the ls3 map sensor??
    By rpmauto in forum Gen III V8 Specific
    Last Post: November 16th, 2012, 06:13 AM
  2. ZR1 Map VE Scaling
    By FreshDA9 in forum Gen III V8 Specific
    Last Post: November 5th, 2012, 02:53 PM
  3. ZR1 Map sensor scaling
    By 9secVette in forum E37, E38 & E67 PFI ECM's
    Last Post: October 10th, 2010, 03:49 PM
  4. Tuning Tool not tracking MAP properly?
    By gto_in_nc in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2007, 12:32 PM
  5. MAP Scaling Help
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 7th, 2006, 06:45 AM
