Results 1 to 10 of 14
Thread: LS1B swap into Chevy 3100?
    Jul 2012
    Default LS1B swap into Chevy 3100?
    I'm pondering starting a project truck, and was wondering how many extra components beyond the PCM really is required to make one of these run? I know there are many problems if you flash the wrong vin in, but will I have any problems if I take a 6.0, 4L80 and PCM and drop it into an old truck?
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Apr 2008
    no you just need the stand alone harness or modify youre own and turn off codes for what you dont use
    stock sucks
    Jul 2012
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    You can put whatever VIN you want into it, EFILive doesnt care what the VIN is.
    Jul 2012
    So the problem is just when it's a vin mismatch with the other modules?
    I knew EFI didn't care, I just assumed the ECM did unless it was a dealer flash
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    Quote Originally Posted by Wheelz View Post
    Yes, if the VIN in the PCM/ECM (TCMs are pretty forgiving, at least the T42s) doesnt match the BCM/ABS/etc, then you run into issues. In a swap truck, it's not an issue. Heck, you could put the original VIN from the 3100 into it if you wanted!
    The dealer would just see this and then enter the desired VIN into Tis2Web before flashing the module.
    Jul 2012
    Ok. Thanks. I'm going to look at one tomorrow so well see.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    May 2013
    Depending on the year don't forget about the Throttle Actuator Control Module (TAC) and the Accelerator Pedal w/ sensor. If it's 02 or earlier good chance it was Cable Driven throttle body and you don't have to worry.
    Jul 2012
    Quote Originally Posted by jbettcher View Post
    Yeah thanks for that reminder. The pedal and sensor is what I would forget
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    May 2013
    When I first started my LQ4 swap I only had PCM, throttle body and harness. The guy who stripped the truck forgot about the pedal and the module in between pedal and PCM. Cost me more than the LS6 intake for those 2 pieces, was a little upsetting.
  1. do you need an LS1B PCM ?
    By Boost in forum Gen III V8 Specific
    Last Post: February 19th, 2013, 10:39 AM
  2. ls1B PID's
    By racerx004 in forum Petrol / Gas
    Last Post: November 13th, 2012, 03:05 PM
  3. CKREF PID For LS1B in v7.5
    By mk13 in forum Gen III V8 Specific
    Last Post: July 10th, 2012, 09:40 PM
  4. 4l80 swap into 1/2ton chevy pickup lockup questions
    By AllOutPerformance in forum Gen IV V8 Specific
    Last Post: May 4th, 2011, 08:02 AM
  5. Vortec swap into 57 chevy need help
    By Spdfrk1990 in forum Vortec V6/V8 Specific
    Last Post: February 11th, 2008, 06:02 PM
