Results 1 to 7 of 7
Thread: FJO GENIII wideband controller
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default FJO GENIII wideband controller
    Needed a second wideband controller so I bought a GenIII FJO. I have been using a GenII FJO with serial connection for several years and I have been well pleased with it. Got it today and started looking it over. It does not have the serial style cable but a device that converts to a USB plug. How do I take this to the V2? Also looks like it powers up thru the USB. Does that sound possible? Settings in the V2 does show a selection for the GenIII. Anybody got one of these working?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    You really do need the serial comms connection...
    and a separate power/ground connection.
    Do you have any wiring diagram of its interface (or can you reverse engineer the USB interface, it probably is some serial-to-USB converter)...?
    Dec 2005
    Thanks for taking a look at this Joecar. FJO don't even mention the interface being supplied with the wideband. Looking at the wiring diagram the white/red wire is the only wire that moves data when connected to the PC. To be "serial" that will work with the V2 doesn't it need to be 2 data wires and ground?
    Being that FJO has sold out to Holley I don't believe I'm going to get much help from them on this.
    2-wires+ground: bi-directional serial comms.
    1-wire+ground: single direction serial comms <-- this is sufficient.
    Dec 2005
    But which one is the V2 going to want?
    For example:
    - AEM UEGO only has a single wire (transmit) from which V2 reads lambda;
    - LC-1 has two wires (transmit/receive) from which the V2 reads lambda (transmit) and writes commands (receive).
    It all depends on the wideband.
  1. FJO wideband install
    By sinr98 in forum Gen III V8 Specific
    Last Post: April 27th, 2010, 03:15 AM
  2. FJO wideband install
    By sinr98 in forum General
    Last Post: April 27th, 2010, 02:03 AM
  3. fjo wideband
    By articSS in forum External A/D inputs
    Last Post: May 27th, 2007, 08:02 AM
  4. FJO wideband compatable?
    By BackinBlack02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2006, 03:25 PM
  5. FJO Wideband & EFIlive?
    By 67SS509 in forum General
    Last Post: January 11th, 2006, 12:59 AM
