Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: Update: May 20, 2013
  1. #41
    Close all EFILive applications.
    Run the program:
    \Program Files\EFILive\Drivers\Utilities\FT_Prog_v1.12\FT_P ROG.exe
    (it can take a while for it to start, about 10-20 seconds)
    Select the menu option Devices->Scan and Parse.
    Let me know if you see the following information exactly as shown in the image below.
    (The LocID will most likely be different - that's just the ID of the USB port into which FlashScan is plugged)
  2. #42
    Aug 2010
    Run the program:
    Hi thanks
    It's look same
    shay
  3. #43
    Aug 2010
    Thnks paul for yours help.
    I did System Restore and now it's good.
    I have other question: why the LML E86 is not on the list of the tune?
    Do you think in the future EFILive will support LGH ??
    Thnks
    shay
  4. #44
    Quote Originally Posted by shay View Post
    Thnks
    shay
    The LML E86 is supported for flashing only in the V8 software.
    It is not possible to read the contents of the E86 via the OBDII port.
    I presume the LGH use an E86 the same as the LML, if so then it will be supported the same as the E86 (flashing only).
  5. #45
    Aug 2010
    How it's work?
    1. You will send me the modified or Stock cal file for the E86 and I flashing via OBD-II ??
    2. What is the price for flashing one ECM?
  6. #46
    How it's work?
    No, we do not supply stock or modified cals for E86.
    The tuners that are using EFILive's flashing option for E86 extract the calibration from the E86 by reading the flash chips directly from the E86 using a dedicated hardware interface.
    EFILive provides and import facility to import the 3 raw binary files that are produced by that dedicated hardware interface.
    The import option is available in the V8 software under [F8: Tools] -> [F3: Import]
    Flashing an ECM requires a single VIN license. Each VIN license costs USD 125.
    https://www.efilive.com/index.php?pa...mart&Itemid=54
  7. #47
    Nov 2005
    How it's work?
    Further to Paul's post, you will find a detailed write up on how LML will work with our software, and the challenges it presents to tuners in our March newsletter.
    Here is the link http://myemail.constantcontact.com/E...id=mP_ob71EhBE
    Cindy
  8. #48
    Aug 2010
    Can I buy Stream license for A86?
  9. #49
    No, there is no stream for the E86 ECM.
  10. #50
    New Update posted here:
    http://forum.efilive.com/showthread....937#post191937
  1. 2013 Cadillac ATS 2.0L..
    By scdyne in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 10th, 2013, 01:50 AM
  2. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  3. EFILive RC 2 (March 28, 2013)
    Last Post: April 9th, 2013, 12:24 AM
  4. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 10:00 AM
  5. 2013 models supported?
    By horst in forum General (Petrol, Gas, Ethanol)
    Last Post: December 21st, 2012, 10:53 AM
