Results 21 to 30 of 50
Thread: Update: May 20, 2013
  1. #21
    Jan 2011
    Going back to the April 23 release did not help. So, after I update the bootblock it just reports $0101 device not responsive.
Name:	V2 stuck in deadpoll.jpg
ID:	15095Click image for larger version.
Name:	V2 stuck in deadpoll 1509601.jpg
  2. #22
    Quote Originally Posted by ATPCummins View Post
    Just downloaded the latest software. I don't see the "see dealer" timer in the 6.7L cummins tunes. Is this timer already maxed out and just not displayed?
    Cummins cal files have not been updated, the additional test parameters are only available in the beta section releases
  3. #23
    Nov 2005
    Quote Originally Posted by Lennart View Post
    I was unaware this video of myself made it that far
    Grüße aus Deutschland....do I need to translate?!
    Hi Lennart,
    Ross and I were going through some old Duramax stuff last week and we came across some of your emails from like 4 or 5 years ago and commented that we hadn't heard from you in a long time. Glad to see you are still around and posting.
    Cindy
  4. #24
    No need to translate, Google can do that for us, but I'd love to know what that kid is yelling about in a short summary, must have been bad what ever he's computer was doing.
  5. #25
    Quote Originally Posted by VTuner View Post
    and my V2 is now in deadpoll mode but it will not allow me to update the firmware
    If the two orange LEDs are flashing its in deadpoll and the boot block is ok.
    If the EFILive control panel does not show the boot block version number then there is a USB comms issue between the PC and the V2, that needs to be fixed first.
    It is possibly a USB driver issue.
  6. #26
    Aug 2010
    Hi
    After I update the Firmware I got message No device connected.
    win xp 32
    boot block 2.07.04
    I try another PC same .
    I try 'deadpoll' mode (two orange LEDs is flashing)- same.
    In Device Manager there is no problem with the V2 Driver It's look good , I try to uninstall USB driver and install without success.
    Can You help me???
    Please connect a FlashScan or AutoCal USB device.
    If a device is connected, ensure it is not being used by another application such as the EFILive V7.5 Scan or Tune Software.
    shay
  7. #27
    Paul,
    The V2 readiness states now have their formatting all jumbled up.
    2.7.41.
  8. #28
    Apr 2007
    Re: No device connected
    I ended up unstalling v7.5 and v8 completely. Then reinstalled software and updates. Knock on wood, everything seems to be working now. If all else fails, you may want to try this ...
  9. #29
    Aug 2010
    QUOTE=draftee;191756]Re: No device connected
    I ended up unstalling v7.5 and v8 completely. Then reinstalled software and updates. Knock on wood, everything seems to be working now. If all else fails, you may want to try this ...[/QUOTE]
    I tried it's not work.
    In the Device Manager I think the Drivers looks good
Name:	Device Manager.PNG
  10. #30
    Quote Originally Posted by shay View Post
    [/QUOTE]
    The device name in the USB list is not correct. It says "USB Serial Converter". That is not FlashScan. The entry for FlashScan will show as "EFILive FlashScan V2".
    The driver that you have highlighted is for another device using the same FTDI chipset. It may even be for FlashScan but using the generic (USB serial converter) drivers instead of the EFILive supplied customized D2XX drivers.
    I recommend uninstalling the FTDI drivers like this:
    Disconnect EFILive
    Run the program: \Program Files\EFILive\Drivers\Utilities\Remove FDTI USB Drivers\CDMuninstallerGUI.exe
    Enter the Vendor ID as 0403 and the Product ID as E4A0, then click [Add].
    Enter the Vendor ID as 0403 and the Product ID as E4A1, then click [Add].
    Enter the Vendor ID as 0403 and the Product ID as E4A2, then click [Add].
    Enter the Vendor ID as 0403 and the Product ID as E4A3, then click [Add].
    Then click [Remove Devices].
    Then reconnect EFILive and when the "Installing USB drivers" balloon appears in the system tray, click on it and select "Skip obtaining drivers from Windows update".
    Then go into the device manager and locate FlashScan. It will probably be highlighted with a yellow tag indicating it doesn't have a driver. It may not even be in the USB section.
    Right click on it and select install (or update) drivers. Choose to locate the drivers yourself and navigate to the folder:
    \Program Files\EFILive\Drivers\EFILive\Win-XP-Vista-7-8 and click [Install] or [Ok]
  1. 2013 Cadillac ATS 2.0L..
    By scdyne in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 10th, 2013, 01:50 AM
  2. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  3. EFILive RC 2 (March 28, 2013)
    Last Post: April 9th, 2013, 12:24 AM
  4. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 10:00 AM
  5. 2013 models supported?
    By horst in forum General (Petrol, Gas, Ethanol)
    Last Post: December 21st, 2012, 10:53 AM
