Error report generated by EFILive at 13:08:26 on May 21, 2013
Error code: ERR_NOCABLE/31
No interface cable found.
EFILive Version: 7.5.7 (Build 204)
Platform: Windows NT
Version: 6.1 (build 7601)
Processor type: Pentium 1995MHz
Connected: No
Com port: 0
Com setup:
Requested baud rate: 115200
Cable id: 0
Cable code:
Cable desc:
Cable version:
Cable Firmware date:
Cable model:
Cable Serial number:
Protocols: 0
Protocol list:
Auto connect: No
Scan OBDII info: No
Error retries: 1
Retry delay: 10
Message throttle: 0
Most recently used VIN: 1G1xxxxxxxxxxxxxx (Note: 1)
PCM information
Hardware Number: Unknown
Calibration ID: Unknown
Serial Number: Unknown
Calibration Verification: Unknown
Internal Flash: Unknown
External Flash: Unknown
Not used: Unknown
Not used: Unknown
Not used: Unknown
Not used: Unknown
Not used: Unknown
Not used: Unknown
Stream-Slow scan mode: Unknown
Stream-Fast scan mode: Unknown
Maximum dynamic packets: Unknown
Detected modules:
Report ID: 1651924 (Note: 2)
Notes:
(1) The VIN sequence number is not required for this report and for your privacy it is NOT included in this report.
(2)The report ID is a checksum of the report text and is used to verify the integrity of the report.
