Results 1 to 8 of 8
Thread: Km to MPH
    Junior Member 55chevdelray's Avatar
    Mar 2009
    Default Km to MPH
    I'm noticing that all the table references for speed are Km. Is there a way to change everything in EFI Live to mph references?
    Brian
    EFI Live V2
    55 Chevy with C4 Corvette Suspension
    LS376/480 (E38) and 6L90(T43)
    My Project: http://www.picturetrail.com/sfx/albu...r/55chevdelray
    Jul 2012
    Default Km to MPH
    Under the edit menu, look for something like set default units (it's towards the bottom, like 3rd or 4th from the bottom)b you'll have to have all your table windows closed. Select all and click imperial.
    14 GMC Sierra
    5.3L CC SB 4x4
    Basic tuning....
    In scantool: on PIDs tab: highlight any speed pids and do rightclick->Imperial.
    In tunetool: go Edit->Configure Display Units, for each of the Data, Row, Col columns click once or twice on the column heading, highlight the group of speed items, do rightclick->Data/Row/Col->Imperial.
    Member Dirktdolman's Avatar
    Oct 2014
    Using EFILive 8 I went to F:5 BBX, F:2 Scan, Read, BBL Enabled Controller (I selected LS1B), right clicked on VSS and selected properties, I activated the Custom PID Properties, Clicked on the down arrow in the Quick Select box and selected the MPH option, Clicked OK, Clicked the down arrow next to SAVE and selected Save As, I choose a location and created a file name I could remember then SAVE, next I clicked the down arrow next to Program and selected Program Selections and Configuration Files (slower).
    I also did this for all the temp readings to change from C to F
    Will this work? IDK yet but I will try it tomorrow.
    Yes, that works for setting the custom units for V2 BBL...while logging press ENTER on V2 keypad to show custom units.
    Edit: works for V2 LCD during BBL.
    Oct 2014
    I tried that and it does not change.
    Quote Originally Posted by Dirktdolman View Post
    Where, in V7 scantool, V8 scantool, or V2 LCD during BBL...?
    Oct 2014
    The enter key would not change the screen on the V2. Now that I have activated the Custom PID it works.
  1. Converter unlocking at 80 mph
    By Cool28 in forum Gen III V8 Specific
    Last Post: April 13th, 2012, 10:25 AM
  2. How about a mph/retard?
    By Highlander in forum Custom Operating Systems
    Last Post: September 5th, 2009, 09:41 AM
  3. KM/H to MPH help
    By nonnieselman in forum Tips and tricks
    Last Post: November 27th, 2006, 09:36 AM
  4. KMPH to MPH conversion
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: February 22nd, 2006, 02:09 AM
