Results 11 to 20 of 28
Thread: V2 won't data log
  1. #11
    Senior Member Quinton's Avatar
    Apr 2013
    Default V2 won't data log
    Any ideas?
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
  2. #12
    Feb 2013
    Quote Originally Posted by Quinton View Post
    I can't find program all on my drop down?
    See the red program button?
    There's a drop down arrow beside it.
  3. #13
    Apr 2013
    Quote Originally Posted by IJ. View Post
    Ya I did that to. Still nothing. I let it program all and it still didn't work.
    [/SIGPIC]
  4. #14
    Apr 2013
    Any ideas?
    [/SIGPIC]
  5. #15
    Feb 2013
    Did you "format CONFIG file system" first?
  6. #16
    Apr 2013
    Where do I go to do that? Don't remember doing it.
    [/SIGPIC]
  7. #17
    Feb 2013
    Same drop down arrow
  8. #18
    Updating the firmware (obtained by updating the software) is not sufficient (you will see those screens you posted)...
    [ BTW: don't do Update, but rather download the software and manually install it, and use EFILive Explorer to manually flash the bootblock/firmware into V2) ]
    You must also run the V8 S&T software, goto BBx and on each of the Scan and Tune tabs make sure you edit/add items that are for your ECM (you can delete the others)...
    [ BBx Scan tab = this is where you define pidlists for your ECM; BBx Tune tab= this is where you identify you ECM ]
    then you have to do Program All (doing Program is not sufficient)... you access Program All via the downarrow next to the Program button.
    And also: in Win7/8 you have to run V8 S&T or V8 EE as Administator.
  9. #19
    Apr 2013
    Okay so for any time I want to use my v2 for data logging or watching pids off of it I have to hook it up to the the vehicle and then program all for the pids for that vehicle?? And why is it showing this after I click display data or select pids?
    [/SIGPIC]
  10. #20
    No, something else has gone wrong... can you retrace your steps...
    Did you also format the Config space before doing Program All...?
    Did any of the bar graphs on the BBx display go red (not enough room)...?
    Do this from BBx:
    - format the Config space,
    - open the Options.txt file (containing your pidlists and ECM),
    - check that the bargraph at bottom left is not red )post screenshot),
    - do Program All, wait for it to finish.
    Edit: note that he has no pids in the pidlists (see what Blacky says below).
  1. Replies: 8
    Last Post: May 19th, 2011, 03:36 AM
  2. How to Data Log?
    By duramax07tmd in forum Diesel
    Last Post: May 13th, 2011, 01:28 PM
  3. Get log data off flashscan?
    By pavetim in forum Black Box Logging
    Last Post: November 23rd, 2010, 12:22 PM
  4. I can no longer log data
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2009, 12:09 PM
  5. Replies: 11
    Last Post: October 20th, 2008, 08:47 AM
