Results 1 to 8 of 8
Thread: Ls2 Hot start Problem
    Apr 2009
    Default Ls2 Hot start Problem
    Hi Guys, I have a Cobra kit with a 2005 Ls2 with E40 ECU and 24t Reluctor wheel. It runs a std 2005 Pontiac GTO tune file with no evap... Starts fine from cold first time every time. When the engine has warmed up it runs fine with no problems. All water and oil temperatures remain stable at normal operating temperatures. When I stop the car, turn the engine off and the car is left for a while, say 5-10 mins or even up to an hour or so. When I attempt to re-start the engine it cranks over and over and over but will not fire up !!!! The fuel pump kicks in ok, the battery is good and there are no fault codes present.....It does eventually fire up and sometimes slugishly.....Or if I stop cranking wait a few seconds and then crank again it satarts almost imediately.... It had a new Crank Sensor last year after it would not start at all after winter storage....So I dont think this is the issue....This just happens when the engine is warm... Does anyone have any experience of this??? If so did you get a fix ??
    Junior Member c.u's Avatar
    Jul 2011
    Is the motor stock?
    Apr 2009
    Hi, Yes completley standard engine all round. No mods.. :-)
    What is pressure at fuel rail...?
    Is your FPR manifold-referenced or not...?
    Apr 2009
    Hi, The fuel pressure at the rail after starting is 60 PSI. When cranking from hot it only makes 20 PSI and then as you keep cranking it slowley rises to 60 psi and then starts....Sorry I do not quite know what you mean by FPR manifold reference?
    May 2012
    Default Re: Ls2 Hot start Problem
    Does your fuel pressure regulator connect to manifold vacuum or not is what he meant.
    Apr 2009
    Quote Originally Posted by krisr View Post
    Hi Krisr, Ahh, I understand....Er No it is not connected. Just blocked off.
    If rail pressure is not at full running pressure (60 psi in your case) right from the start, then there is your hot-start problem.
  1. Help with HOT start adjustment
    By zbadestz in forum E37, E38 & E67 PFI ECM's
    Last Post: May 28th, 2012, 03:28 PM
  2. Hard to start when hot
    By W_D_R in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2010, 01:26 PM
  3. Hot Start Question on LS7
    By fperra in forum Gen IV V8 Specific
    Last Post: September 23rd, 2009, 11:24 AM
  4. LS7 Hot Start Issue
    By hapnermw in forum E37, E38 & E67 PFI ECM's
    Last Post: August 20th, 2009, 05:24 PM
  5. Hot start troubles
    By PowerKraus in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2005, 10:15 AM
