Results 1 to 10 of 11
Thread: 04.5 LLY wont accept DSP5 tunes or data log
    Jun 2012
    Default 04.5 LLY wont accept DSP5 tunes or data log
    trying to get my truck set up for dsp5 tunes
    ive gone through all the steps correctly for making the tunes in dsp5 format
    i know for a fact the wires are pinned correctly, even have tried holding the black wire directly to ground and stil nothing
    everything is up to date in both v8 and v7.5
    when i full flash the new dsp5 tunes in and go to switch tunes, it just stays in the stock tune and wont change
    when i try to data log the pids for dsp switch it says something to the extent of "pid cant stream, must be in dynamic stream mode" and ive made sure it was in that mode, and tried it in every mode i can with no luck
    Thats pretty much a short and sweet version of what ive been fighting with
    anyone ever had this problem?
    any ideas how to fix it so it works right?
    Dec 2005
    Is the tune set to serial or hardwired for the switch ?
    www.mscservices.net
    Jun 2012
    Quote Originally Posted by GMC-2002-Dmax View Post
    Hardwire
    Member Motorzane's Avatar
    Jun 2011
    How many PIDs do you have selected? Try unselecting all PIDs and only select the DSP PIDs and see what happens. I have had that message pop up before when I had a PID that was not supported by that controller.
    Jun 2012
    Quote Originally Posted by Motorzane View Post
    I only have the 1 dsp Pid selected
    Apr 2008
    i just had one where the voltage was not set when i upgraded to dsp5 could see voltage change at switch but not chaning tunes. its worth a look
    stock sucks
    Jun 2012
    Quote Originally Posted by tokymon View Post
    Ill try anything at this point.
    How to check that tho?
    I'm still learning all the fun EFI stuff lol
    Apr 2008
    if you log dsp5 voltage lb7-lly you should see voltage change on the scanner and its the first table under youre dsp5 tunes ( sorry at work not at tuning computer)
    stock sucks
    Jun 2012
    i cant log to see it tho, thats half the problem lol
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Default Re: 04.5 LLY wont accept DSP5 tunes or data log
    What voltages does it say each dsp tune is when viewing the calibration in tune tool?
  1. 2004.5 LLY can I use 2006 LLY tunes?
    By Badass_chris in forum Duramax LLY
    Last Post: October 22nd, 2012, 04:16 AM
  2. 06 LLY wont start
    By redyrxela in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 16th, 2012, 05:45 PM
  3. 05 LLY, changed vein position on dsp5 tunes
    By jcbduramax in forum General (Diesel)
    Last Post: February 28th, 2011, 09:45 AM
  4. Dsp5 lly help!
    By josh08 in forum Duramax LLY
    Last Post: December 6th, 2009, 02:33 PM
  5. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
