Results 1 to 9 of 9
Thread: $0333 error...
    May 2013
    Default $0333 error...
    I have been having a hard time getting a new program to load.
    I had a few error codes but after repeated attempts I finally got it to start loading. Then got an error midway through the install. So it didn't load. Other attempts failed as well. So did trying to reload the older program. I finally did a Full install and got the old program back on and the car running again. I can't get the latest program to load though.
    This latest program is a MAF only file to data log it and monitor it using the wide band sensor.
    Chuck from Corvettes of Westchester has been creating the tune files and has been real good to work with.
    The car is a 2004 Corvette.
    Any help would be appreciated.
    May 2013
    Now I can't get anything to load or even to read the cars computer.
    Did you flash new firmware into your V2...?
    Did you do BBx Program All...?
    May 2013
    I am using an AutoCal and not the V2.
    May 2013
    Also, I have been wondering about my cable. Some of the pins in the plug are shorter than others. Is this normal?
    Quote Originally Posted by Danny Richie View Post
    Still need to do Program All...
    ( Program does not write all the needed files, Program All writes all the needed files )
    Yes, that's normal... unless you modified the pins.
    May 2013
    Okay, I am still very much a rookie at using this system. How do I do a "Program All"?
    If you are referring to scrolling down a few clicks further and doing a "Full 1" load then I have tried that. I get the same code.
    I even get this code if trying to run a "Read 1".
    May 2013
    Thanks,
    The pins have not been touched.
  1. Replies: 8
    Last Post: March 20th, 2018, 06:47 AM
  2. $0333 error
    By JLawson in forum Duramax LB7
    Last Post: June 21st, 2013, 04:31 AM
  3. $0333 Error
    By Dmaxink in forum AutoCal
    Last Post: August 8th, 2012, 01:24 PM
  4. Error 08 on my LM-1
    By Slowrc in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2010, 04:43 AM
  5. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 03:22 PM
