Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Update: May 25, 2013
    Default Update: May 25, 2013
    EFILive encourages customers to use this public update in their production environments.
    Important:
    This latest software update requires updated USB drivers (V2.08.28). You cannot use this version of the software with older versions of the USB drivers.
    If you are having difficulty connecting to FlashScan/AutoCal after installing this update, DO NOT DOWNGRADE THE USB DRIVERS.
    Download here:
    Updates:
    V7
    • None.
    V8
    • On BBX window the "Space Available" meter disappeared when View->Small Buttons was active.
    • Saving a BBX configuration file would cause the custom units for PIDs to be lost.
    • Access Violation could occur when reading a BBX configuration file from Disk or from a FlashScan/AutoCal device.
    Firmware
    • Fixed corrupt "System Readiness Tests" result display.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 233
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 227
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.04 (Dec 12, 2011
    To view the installed version, Select F7: Licenses (in the V8 Scan and Tune software).
    Firmware: V2.07.42 (May 25, 2013)
    Dec 2006
    Thank you for the update
    Dec 2012
    Trying to read my 5 speed Allison tune... It gets to the "Trying MFG Key" then I get "ERROR: $0331"
    Josh
    '04 GMC LLY
    Try reading with the "Try Alt Keys" and/or "Assume Lock is Faulty" check boxes checked.
    Lifetime Member zfuller123's Avatar
    Jan 2010
    having issues after bench reading an LMM in v8. after 15 second countdown, get an error saying merge error... "...\program files...\v8\merge\...." can't find merge.cmz or something like that. Trying a clean install right now running as administrator again.
    2005 Crew Cab Dually Duramax
    Big turbos, big injectors, big pumps, crazy heads AND a flux capacitor...
    Best run so far on street tires: 11.14 @ 128.8 mph
    Nov 2010
    Couldn't open V7.5 Tune Tool with V2 plugged in for a LONG time after install. Now after a shutdown and restart it opens fine...FYI.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    May 2010
    OK I update the software to the latest version
    I Pulled the tune from 2013 V6 Camaro E39A ECM yesterday
    I had a strange problem after pulling the tune file i uploaded the file twice to the car after some modifications then i could not open the file using V7.5 even i tried to read the file which i uploaded to the car then save it and open it via V7.5 but an error message shown that its a bad file format i attached the screen shot
    by the way I still could open the first file i pulled from car and the second file i modified but not the third one
    EFILive Tuner
    The calibration in that ECM is not properly supported by the EFILive software yet. We will complete support for it in the next major update.
    Came across an unsupported E78 and T76 today, should I email the files to support AT efilive.com?
    Yes please.
  1. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  2. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  3. EFILive RC 4 (April 10, 2013)
    Last Post: April 22nd, 2013, 03:07 AM
  4. EFILive RC 2 (March 28, 2013)
    Last Post: April 9th, 2013, 12:24 AM
  5. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 10:00 AM
