Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: cax error after V7.5 update (build 232)
  1. #41
    Jul 2003
    post the cax file.. i'll fix the error.
  2. #42
    Oct 2006
    Found my error. Per post #10 in the cax update thread, I placed it in the configuration file. Moved it to the calibration file and deleted my old cax thread and now it loads without the warning. Thanks.
    2000 Formula: 12212156, bolt-ons, 3600 stall, 3.42's.
  3. #43
    Dec 2015
    Apparently when you call something B8101 weird things happen. I took pixs.
    cav.pdf
  4. #44
    Yeah don't use....
    B8101 to B8106
    OR
    B8151 to B8156
    These are used by the Virtual VE tables in various ECM's.
  5. #45
    Dec 2015
    Yeah don't use....
    B8101 to B8106
    OR
    B8151 to B8156
    Good to know. Of course most people probably wouldn't run into this issue.
  6. #46
    In a cax you would use table id's in the range B9000 to B9999 to avoid colliding with any predefined tables id's.
  7. #47
    Dec 2015
    752 of those are currently occupied by the mess that is the DTC table. I suppose I could make everything higher than B10000 (assuming there isn't anything in those ranges). I know the program will accept the values, but I'm not sure if they will cause other hidden issues by adding another digit.
  8. #48
    Quote Originally Posted by Snipesy View Post
    LOL yes, Bosch DTC tables are a joke.
  1. Replies: 4
    Last Post: September 16th, 2012, 08:54 AM
  2. So who can build a cax file?
    By Whipped383 in forum CAX Files
    Last Post: June 7th, 2011, 12:40 PM
  3. build 100 DSP 5 error
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 22nd, 2009, 03:31 PM
  4. Build 74 update problem
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 03:57 AM
