Can someone look at this tune file and see if the injector data is entered correctly (disregard the rest of the tune, its from a stock Silverado, just want to see if I'm doing the injector data correctly). My fuel trims are going max negative on decel no matter how much I reduce the MAF table. My tuner thinks I'm hitting the minimum pulse width of the injectors/data. The IBPW PID shows ~1.77-1.81ms during decel, and ~2.15 at idle. My tuner said he's never had to adjust the minimum pulse width, small pulse adjust, etc of the injectors.
It's an '01 Silverado with the stock manifold referenced FPR (around 58psi with reference line disconnected) and FIC Bosch 60# injectors at 3 bar. The data they sent they scaled for me for 4 bar.
Thanks!
