Results 1 to 3 of 3
Thread: Help with bbx
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default Help with bbx
    HI guys
    im having trouble with the BBX programing the v2
    since i downloaded the latest ver of v8 2.2 and 5.7 10 days ago
    i don't seem to be able to reposition the pids on the v2 screen like you used to be able to ,i can add or subtract a pid no worries BUT it seems to just go into any position ( generic ) when you program the v2
    tryed slow / fast / reconfig /
    i have enclosed a page shot of how i'm trying to get the v2 screen to look
    cheers
    There is a newer update which should fix that.
    Update-May-25-2013
    Remember to flash V2, then in BBx do Program All.
    Aug 2008
    hi joe
    i have just done that ( down loaded the bouth ver upgrades ) re flashed the USB drivers and the boot block
    they are boot block v2.07.04 dec 12 ,2011
    firmware is v2.07.42. may .25.2013
    drivers are v2.08.28
    and reprogrammed the BBX (at least you can reposition the pids on the v2 screen now )
    thanks BOB
  1. Bbx and pids
    By Harrismarine in forum Black Box Logging
    Last Post: September 5th, 2012, 11:59 AM
  2. 06 duramax bbx help
    By rodder55 in forum Black Box Logging
    Last Post: June 12th, 2012, 09:49 PM
  3. BBx troubles
    By jollyrogr in forum Diesel
    Last Post: August 8th, 2011, 05:09 AM
  4. new v2 starting from bbx 0024
    By restless@westnet.com.au in forum General
    Last Post: May 24th, 2011, 11:26 AM
  5. BBx Cal Flash?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2011, 11:20 AM
