That concerns me there is a fuel system problem. it has a walbro intank pump but i guess anything is possible.
Since this is a tuning site.... LS1 swap, 224/228 .588/.588 114+1 , LS6 intake , Ported TB, LS6 Valley cover (huge difference in oil usage!) 36# grand prix injectors, SLP Thirdgen dual air box cold air, Stage 2.5 Ported PRC ls6 heads, Hawks ls1 1 5/8 swap long tubes, SLP Thirdgen Catback t56, spec 3 clutch, S60 street 3.73 rear. LC-1 WB , Roadrunner
No, not necessarily - I noticed that the injector flowrate table slope is kind of steep - that is why I questioned where the data came from in an earlier post. That will effect the shape of the VE table - but it doesn't mean that there is a problem. Go ahead and log the tune I posted...
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
Log_ol-2.efi
I tried to hit as many as possible , hopefully the throttle was smooth enough for most of it.
Its coming along - give this one a hit - do a little longer WOT pull this time too.
GM EFI Tuner
CorvetteFlorida.com
2002 Corvette Z06
427 RHS block built by LME
STS rear mounted twin turbos
It nearly died on the operating table, but I'm bringing her back.
Log_ol_3.efi
tried some more wot. I hit the limiter once.
and thanks again!
Go ahead and hook the MAF back up and load this tune. Add MAF frequency to the pids for logging. Don't hit it too hard this time at WOT - just one quick pull up to 6000 rpm to see where it is.
GM EFI Tuner
I will give it a try tomorrow night. do you want a full log or just the run to 6k
