Results 11 to 20 of 23
Thread: How to make tune tool mark the selected area in scan tool ?
  1. #11
    Senior Member KhakiCummins's Avatar
    Sep 2011
    The cal_link file is actually really easy to update. It is all plain text and you can pretty much use any section of it as a reference to build the links for the tables you want. I edited mine for the CM2100 (CMC) ECMs. It took a little time but that was all.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
  2. #12
    Quote Originally Posted by wesam View Post
    Here is it
    Please Joe write the lines you will add to the link file so i could know the logic
    Are you logging E38.APCYL_DMA...?
    Edit:
    Look in your cal_link.txt file, search for E38.APCYL_DMA, it is already there (under the [E38] section)...
    please ignore my edited cal_link.txt since I edited the wrong section.
  3. #13
    Hmmm... doesn't seem to work... do you have a log file...?
  4. #14
  5. #15
    Lifetime Member wesam's Avatar
    May 2010
    In my Calc_Link file there is no E78 or E39 field so i could look under ?!!
    EFILive Tuner
  6. #16
    On either of those, what APCYL pid are you logging...?
  7. #17
    May 2010
    For e38 I'm using E38.APCYL_DMA
    But for E78 I don't know what will work for the scanner because there is nothing written in the X axis of the HO table
    EFILive Tuner
  8. #18
    Are you logging E78.APCYL_DMA...?
    Try the attached calc_link.txt file (I copied the [E38] section, renamed it to [E78], renamed the pids to E78.APCYL_DMA):
  9. #19
    May 2010
    Thanks Joe
    Could you teach me the method of modifying the link file so i could do it my self
    EFILive Tuner
  10. #20
    Open cal_link.txt with Windows Notepad, search for [E78] say, then search for B5101 say, then look at ROW and COL, whichever one matches the pid you want to link (e.g. APCYL grams) add the exact full pid name (e.g. E78.APCYL_DMA) with a comma separating it from the pid name already there, save file, restart tunetool.
  1. Replies: 44
    Last Post: July 8th, 2010, 11:06 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
