Results 1 to 4 of 4
Thread: Quick wideband hookup question
    Feb 2013
    Default Quick wideband hookup question
    Quick question about hooking up a wideband to my V1 unit. It's an AEM wideband with a white wire for 0-5V analog output. This wire will go to either Pin C (EXT.AD2) or Pin E (EXT.AD1). But do I need to hook anything to Pin D the common ground? If I do need to, would I just hook it to the same ground that I'm using to feed the gauge?
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
    Yes, ground, yes same is usually ok (if there is not a specific signal ground/return wire).
    Feb 2013
    Thanks! I used the same ground that I used for the gauge, seems to be working well. The reason I was confused was that my Prosport wideband had a separate ground for data logging and the AEM doesn't.
    May 2012
    I just used the white to AD1 EXT. Works fine
  1. Quick question
    By 2007chevy5.3l in forum Gen IV V8 Specific
    Last Post: September 21st, 2011, 02:42 PM
  2. Input on Wideband Commander hookup.
    By John02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2009, 03:03 AM
  3. quick question
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 17th, 2009, 10:55 AM
  4. Question regarding LC1 hookup for calibration
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 12th, 2006, 07:45 AM
  5. LC-1 hookup question
    By PSWired in forum General
    Last Post: July 13th, 2005, 01:48 AM
