Results 1 to 4 of 4
Thread: E37, E38, E67 Operating System Compatibility List.
    Aug 2006
    Default E37, E38, E67 Operating System Compatibility List.
    I am messing with a 2009 GMC Denali and the E38 service number is 12630500. The compatibility PDF shows the 12630501 service number but not the 500 number. Does anyone know if the 12630500 ECM is compatible with the other O/S-ECMs listed in the 2009 column?
    Thank You,
    Jeff
    Jeff, the list is not based on ECM Service numbers, rather the OS number the ECM has in it.
    Aug 2006
    WOW, I was way off base. Thank You for the clarification.
    Jeff
    Aug 2006
    Here is some info a friend gave me. It is the correct way to read and understand the label on the ECM. Maybe I am the only guy who didn't know this---Maybe not. Hopefully this will benefit someone else.
    Couple of things .... 12630500 is the Hardware Number, not the Service Number.
    If you look at the label from the top, from left to right ... it will probably begin with E38 (not all do) followed by 12630500 (Hardware Number), followed by the BCC (probably YRUJ).
    Under this will be the bar code. Under this will be the ECM Serial Number (with the BCC inserted after the first two digits).
    Under this will be the Service Number - 12625455 (for a 2009 E38).
    If it is a 2009 Escalade, the ECM OS is probably 12630501 (coincidentally similar to the Hardware Number).
  1. E38 - E67 OS compatibility list
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: March 30th, 2015, 10:09 PM
  2. 2012 Escalade E38 operating system not recognised ?
    By Mike@sic in forum E37, E38 & E67 PFI ECM's
    Last Post: November 5th, 2012, 08:43 AM
  3. E39 Operating System Compatability List
    By engimuneer in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 30th, 2012, 10:10 AM
  4. e37 operating system question
    By doctor_cad in forum E37, E38 & E67 PFI ECM's
    Last Post: August 4th, 2011, 06:18 AM
  5. E37,E38, E67 Speed Density
    By L31Sleeper in forum E37, E38 & E67 PFI ECM's
    Last Post: July 19th, 2010, 10:06 AM
