Results 1 to 7 of 7
Thread: Breaking up in Boost Randomly
    Aug 2011
    Default Breaking up in Boost Randomly
    Got my car set up on e-85 on 5 lbs of boost and im having an issue of breaking up, it will happen on one WOT pull and not on the next. AFR while its doing this looks good and so does the timing. it its like hitting a wall. Im logging the basic stuff but what else can i log to see whats going on? its a 3 bar sd (no Maf) OS with PE disabled for tuning. Ive read that logging CYL_DMA may lead to some insite.
    What does wideband show...?
    If PE is disabled, are you otherwise ensuring sufficient richnessl at load/WOT...?
    Can you verify that you get spark during the pull (there is a cheap tool that glows when placed next to plug wire).
    Is rail pressure ok...?
    Are you getting a MAF DTC (you should).
    Yes, log DYNCYLAIR and a few others.
    Can you post tune file and log files.
    May 2012
    SC or Turbo? What type fuel system and controller? What type of blow off or bypass valve?
    Jan 2012
    Need more info on the setup. What spark plugs are you using? What's the fuel system? Injectors? What is the injector duty cycle?
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
    Aug 2011
    Quote Originally Posted by andysc3 View Post
    found the issue, overly rich. The equasion i used was wrong for the wideband i had.
    Jan 2012
    Glad to hear you got it sorted out. Still courious about the setup though.
    Aug 2011
    its a trickflow headed lq4 with custom turbo cam and a b/w s480. E-85 on 5 lbs of boost went a best of 9.87 at 156 last friday on a conservitate tune. 5500+ DA. A1000 pump/reg, semins 80LB injectors and 80% D/C on a ngk 7 plug gapped at .030
  1. "Breaking up" when in boost?
    By DrX in forum Gen III V8 Specific
    Last Post: August 15th, 2011, 03:40 PM
  2. Randomly chokes out...
    By LBZoom in forum Duramax LLY
    Last Post: August 15th, 2010, 08:05 AM
  3. Timing going NEGATIVE randomly...help please
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2009, 03:25 AM
  4. ASR randomly turns off
    By CoryF in forum Gen III V8 Specific
    Last Post: October 9th, 2008, 06:52 AM
