You may not want to log the MAF at this time. I`v seen it skew reading when tuning sd.
Gave it a try at flattening that area out quite a bit. It didn't make any difference. Looking a frames 2580-2590 of the attached log for example still show the big step up in calculated airmass. The suggested PIDs and fuel states have been logged but I haven't figured out how to rename the SCALEDCORVE yet to review.
Any other ideas on what could do this. I combed back through my tune table by table looking for something related to 3200 RPM and nothing stood out.
If you get a MAF DTC then the MAF is being ignored.
In retrospect, that hump in your VE tables looks wrong...
VE table should look like this: each MAP slice should look like a dyno TQ curve.
Thanks for your input. I have been reviewing the trends and sculpting the table by hand. I have my WB mounted 18" back from turbo exit per Innovate's recommendations and it is clearly at least a frame behind in the logs.
Temperature has been a factor. The first 20-30 minutes of drive time is to be ignored. The car is operating leaner once everything is thoroughly warmed up.
Still, all three auto VE methods seemed to be off by a factor that continues to elude me. Every time I would hit a wall at 6.3% LTFT and then it would jump the other way. I'd like to hear from somebody that is running a boosted E40 and got one of the auto methods to work. I can see why you would want a steady state dyno.
