If you use lean cruisemode with a COS you need to match your PE map trigger to the enrichened cells in B3647. For example, if you command stoich up to 80kpa, then progressively enrichen the cells up to 105kpa, you need PE the map enabler to trigger from 80kpa. Also the TP position enabler will need to be set just above your usual cruise position. This is the only work around I have found to prevent a "rich cruise mode" Which will occur if the cruise timer is hit during an uphill climb.
